CC Performance Relocation Kit
I just installed my coil relocation kit from CC Performance. I also mounted my Rev Extreme catch can, still need to plumb it. Also added BBK TB.
Let me know what you guys think
The install wasnt that bad. You remove the plastic cowling, takes 5 minutes. Then take the nuts off the wipers, close the hood and pull up on the wipers. Make sure you tilt the wipers up off the windshied when doing this , gives you more leverage.
As far as mounting the brackets. I chose the alternate mounting method, you can drill holes under the cowl, this requires a right angle drill, I had one but it looked like a real pain to mark them and drill under there. I chose to take the v shaped mount and open it up so it slides on top of the cowl. All you have to do is trim the v bracket so its not sitting on the windshield. It probably took about an hour to install.
2000, 2010, camaro, cc, ccperformance, coil, ignition, kit, kits, ls, ls1, performance, profomence, relocation, relocaton
