Questions about my car, no sub frame connectors.
2002 Camaro Z28 A4 headers, full exhaust, lifters, springs, 241 heads, motor is stock other wise. SS hood, air box and K&N. Stock tranny and rear. Lowering springs Global west LCA's. Dyno tuned by HP Performance 342RWHP 356RWTQ. If you need to know anything else please ask.
I am going to run my car Saturday I do not have sub frame connectors, I will be running MT sportsman pro's ( I know not the greatest at all but I got a great deal). My questions are will I crinkle the fenders, will I damage the rear end or tranny or anything else. I know anything can happen.
Thanks
Steven
Thanks
Steven
Thanks, I thought it would be ok but wanted to be sure. I plan on having weld in connectors asap. My wife is the only reason I do not have them now, I have only had the car about a month. I want to know what it will do.
Also what is the weak point in the rear end, what breaks. And what needs to be done to make it stronger.
Race your car!
The rear, everything breaks. The gears, the diff, the axles, it all breaks.
To make it stronger: you don't make it stronger, you replace the entire thing with a 12 bolt, 9 inch , S60... take your pick any one will take care of you until you're well into the single digit ET range... just stay away from that POS tru-track diff. Those things are absolute junk, I've seen a car making less power then you are break one, eaton posi, if you can tolerate the chatter a locker, or just put a spool in it and never have another problem. Spool and 33 or 35 spline axles gets my vote. Those parts in a 12 bolt and you can go into the low 8's without breaking it.
