3 channel abs
Old 01-20-2010, 09:24 PM
penningta's Avatar
Default 3 channel abs
Is it posible to make a 9 inch axle housing with out abs and make it a 3 channel abs rear end will minor work or is it machine shop stuff or is it even possible
thanks
Old 01-21-2010, 01:41 AM
SS SLP2's Avatar
A year or so ago someone posted a write up on how to make a 3 channal ,I can not find in saved on my computer now try a search ls1tech, ls1, ls2. ls1howto, I do not remenber. yes it can be done but was quite a bit of work.
Johnny
Old 01-23-2010, 08:44 AM
penningta's Avatar
anyone else I have searched but found nothing
Old 01-24-2010, 06:24 PM
stealth355tpi's Avatar
a buddy and i turned my 4ch 12bolt into a 3ch so i would image you could it. we just had to drill the hole on top for the sensor and sent out the diff to get the reluctor ring installed. if you plan on doing it, give scott a call at dls. fast service and was well priced for the reluctor ring.
Old 01-24-2010, 10:20 PM
SS SLP2's Avatar
thanks
here is write up for a 10 bolt, after reading your post again
I see you ask about a 9 in I have no idea.
Here you go on a 10 bolt
https://ls1tech.com/forums/gears-axl...-3-w-pics.html
