p0446??
p0446??
so my ses light came on today so i went to autozone, the code was p0446 evaporative emission system purge/vent solenoid circuit condition, idk what the hell that means but, any one have any advice, the explanation on the print out says.
probable cause:
purge or vent solenoids defective
check connector and wirring
fuel saturated vapor canister
failed evap vent solenoid
Also, i just finished the motor mounts and installed the tranny mount, i have this wierd vibration up front only when i turn my wheels to the right, so i rotated the tires so its not those, but i really only feel/hear it in my pedal and steering wheel after 30 MPH. any ideas?? thanks guys!
probable cause:
they are poly, i dont think its from that like i said only when i turn the wheel to the right, my driver side strut is making squeking noises whenever i go over bumps i thought maybe it was just cold outside but it does it on every bump. im at a loss, on the P0446 i searched for an answer and no one has seemed to have this problem...weird. alot of people have the P0442 code but not the 446.
