Spohn crossmember mounted torque arm and Texas Speed True Duals
I was looking at a used set of Texas Speed True Duals and was wondering if it would fit around my Spohn crossmember mounted torque arm.
I know on Texas Speeds web site it says not recomended for body mounted torque arms.
Anyone with this set up or is this a deffinate no go?
Thanks!
Thanks!
Hello,
Unfortunately the TSP system will not work with the Spohn tunnel mounted torque arm. The X is right where the torque arm mounts to the tunnel area.
If you look at the link below there are installation pictures of the TSP system and a torque arm we offer. This might help you some-
www.umiperformance.com/2205
Hope that helps,
Ryan
Hope that helps,
Ryan
arm, crossmember, duals, instal, installation, ls1tech, performance, pictures, relocation, speed, spohn, texas, torque, true, umi
