Running through the gears without driveshaft
Old 01-25-2010, 06:50 PM
z28 justin's Avatar
Default Running through the gears without driveshaft
I changed the fluid in my T56 (was getting some grinding) and want to test it out. However, I ripped the rear axle out to clean it up and replace the end seals. Can I row through the gears without the driveshaft in place, or will this get transmission fluid all over?
Old 01-25-2010, 07:06 PM
85MikeTPI's Avatar
fluid will be thrown out of the slip yoke area. Also, without a load on the output you won't get a good idea of the typical grinding.
Old 01-25-2010, 07:18 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Gonna have to wait on that one.
