need some 5.3 help
Old 01-28-2010, 09:42 AM
RNation0001's Avatar
Default need some 5.3 help
im putting a 5.3 in my 67 camaro andgotta question. what do i do about the pcv system. i have the pasenger side hooked up to the intake where it should but what about the driver side back of the valve cover where the grommet is? do i hook it up to a vacuum source too? and how?
Old 01-28-2010, 09:55 AM
pdsq98gt's Avatar
If you are using the truck intake there is a port on the top center of the intake that a hose connects the valve cover to. If you are using a different intake just hook the left valve cover to intake vacuum.
Old 01-28-2010, 11:07 AM
the_merv's Avatar
PCV Valve will go in that spot..I have mine with the PCV Valve in there going to one of the Vac Ports on the Intake. The other side goes from the PCV in the Valley Cover(LS6) to the Intake. Soon I'll have a Catch Can in that spot.
Old 01-30-2010, 07:31 PM
whats the catch can for?
Old 01-31-2010, 02:35 AM
the_merv's Avatar
Catch all the Oil that gets sucked up in the PCV System..
Quick Reply: need some 5.3 help
