slight grind
slight grind
i just purchased a 2002 6spd z28 and there is a slight grind in 3rd and 4th both going from 3rd to 4th and down shifting into those gears, its slight and it will engage those gears and hold, any thoughts..clutch? gears? thanks guys im pretty knew to the 6spds
If it only does it in 3-4 and not any other gears then I would say worn 3-4 synchronizer. This is usually due to plastic fork pads being worn/broken or synchro keys broken/broken and missing. Worst case scenario is the previous owner "missed" these gears and caused this.
These keys were about to fail.
Where is the plastic fork pads?
The synchro teeth are worn. They should have a nice "point"!
What a good synchro supposed to look like.
thanks man..how much would the syncros run me, or what it be more beneficial just to do a rebuild? thanks again for the help you are talking to a former 4l60 guy.. which i could rebuild with my eyes closed lol
