Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
sbc motor mounts
Old 01-30-2010, 03:55 AM
jsut's Avatar
Default sbc motor mounts
where can i get motor mounts for a sbc for a 4th gen camaro, i know BRM makes the k-member wit the sbc/bbc mounts but was looking for mounts, need help guys, thanks
Old 01-30-2010, 05:48 AM
In-Zane Moderator
ZONES89RS's Avatar
I used LT1 mounts.
Old 01-30-2010, 03:28 PM
jsut's Avatar
really????, theyll bolt up to a sbc???
Old 01-30-2010, 04:08 PM
In-Zane Moderator
ZONES89RS's Avatar
2 out of the 2 bolt up, the pattern is not identical, it uses a rear bolt on each side on the LT1 that the SBC doesnt have so you can use the 2 that it has on each side that line up.
Old 01-30-2010, 04:23 PM
jsut's Avatar
ok cool, so i jsut need the mounts from a lt1 k-member then the part that bolts to the block,
Old 01-31-2010, 06:53 AM
vteckiller's Avatar
zone do you have a v8 or a v6 kmember?? i used my stock v6 kmember i got the lt1 mounts and it wasnt even close to working becuase it was too far back and wouldnt even go in...so i had a welding shop make these custom mounts
if you want my lt1 mounts pm me and ill give you a price.
Quick Reply: sbc motor mounts
