1999 Corvette reverse went out.
Old 01-31-2010, 02:39 PM
rollie's Avatar
Default 1999 Corvette reverse went out.
I have a 99 C5 6 speed vette. Today just randomly the reverse went out. When put in reverse the trans just acts like it is in neutral. Has anyone had this problem before?
Old 01-31-2010, 02:50 PM
85MikeTPI's Avatar
Have you taken it on the street since Rev stopped, to see if you still have 5 & 6 or not?
Very odd to lose Rev completely. Has it been grinding for a while? Anything odd happen when trying to engage Rev when it failed?
Old 01-31-2010, 03:44 PM
rollie's Avatar
I got it on the road and yes 5th and 6th are also out. No I havent had any grinding problems.
Old 01-31-2010, 05:08 PM
85MikeTPI's Avatar
Dang... You sheared the extension shaft engagement teeth off of the countershaft.. Gonna need a complete teardown and a new countershaft..
Old 01-31-2010, 10:42 PM
the_merv's Avatar
Damn..how does that happen..
Old 02-01-2010, 07:38 AM
85MikeTPI's Avatar
I've seen it happen most often on vehicles that run under power (racing) in 5th gear. The stronger versions of the T56 (Viper, LS7, SSR, T6060, etc.) have a 1pc countershaft to eliminate it as a weak link.
Old 02-01-2010, 08:06 AM
thesource's Avatar
Its not too common but it does happen. Mike is right about what took a crap on you.
