HELP spedo not working after header/full exhaust install
I finished up installing my pacesetter longtubes ORY and magnaflow catback. Took it for a drive and everything was working. The ory was banging pretty bad will I was driving but I was expecting this because I heard most ORY hit. Got it back in the driveway and looked at my gauges and the speedo was not working. Could I have broken something when the ORY was hitting or could have the longtubes burned through the speedo wire? Where should I start looking first? Thanks?
Yes, it is possible that the VSS sensor or wiring that plugs into the transmission was damaged during install. Check all of the sensors & wiring on to the transmission while your down there. Any damage will be easy to see. Good-luck
