T56 whirring noise in 5th and 6th
My t56 is making a whirring noise in 5th and 6th. It gets louder while under load. Also, it gets louder when I put a little pressure on the stick when in 5th and 6th. All other gears are fine. Just put in new fluid.
Any ides of what it could be?
I have no history with the transmision other than it is supposed to have about 80k miles on it. I just swapped it into a buick roadmaster wagon.
new clutch, pressure plate, hydraulics, and flywheel.
Thanks
Thanks
Thanks
Thanks
The tailshaft housing has to be removed. It's the small tapered bearing on the end of the extension shaft.
It's the bearing on the right.
