STB + Solid Mount clearance
Old 02-07-2010, 12:28 PM
shiv15's Avatar
Default STB + Solid Mount clearance
I currently have stock motor mounts, the SLP stb that came on the car, and a fast 90. There is barely any clearance between the stb and the Fast 90. I'm pretty sure its even contacting when the motor is revved.
I'm going to put in spohn solid motor mounts and i've heard they raise the drivers side of the motor roughly 1/2". Obviously I have a problem on my hands. Are there any stb's out there that will offer me more clearance than the SLP one?
And yes, I know any gain from an stb would be minimal but I do like the way they look in the engine bay.
Old 02-07-2010, 06:48 PM
teke184's Avatar
i've got poly motor mounts, FAST 90, and a BMR stb....without measuring i'd say i have 3/4" of clearance.
no contact problem
Old 02-18-2010, 09:14 AM
shiv15's Avatar
bump. Forgot I had this thread going. The BMR sounds promising.
Old 02-19-2010, 10:23 AM
Arc00TA's Avatar
I have spohn solids in my car, and the intake contacted my UMI strut tower brace. I have to remove it in order to prevent rubbing, but I would assume if you had some thin adapter plates made it would work fine. FWIW, my solids raised my motor almost 1" all the way around.
Old 02-19-2010, 12:40 PM
98TAjwh's Avatar
some washers, or as mentioned above, an adapter plate would raise your stb up a little for more clearance.
Quick Reply: STB + Solid Mount clearance
