Anyone put coilovers in the back?
I was just wondering if anyone on here has put a coilover setup in the back, I thought I had seen someone post it before but couldnt find it
I have the ground control kit out back. It is just a weight jacker set up... uses the stock mounting location for the spring with an adjustable perch under it. No need for a conversion or plate and regular F-body shocks will still work with the ground controls... just another option out there.
