Trouble bleeding brake system
Alrighty, well I took all my calipers off to paint them, and ended up having to let the car sit without any front calipers on it for about a month ( had spares for the rear.) I put all the calipers back on it, bled the brakes (furthest to nearest from ABS block) and still had no pedal. I did this 4 times, same result. So I lent the car to a GM tech of mine, had him run an auto bleed on it with a Tech 2. He bled them 3 or 4 times also. Got great pedal then. Started the car up, pulled it out of the bay, and now its back to no pedal. Just like a squish to the floor.
I haven't messed with the car in a while since I've had other stuff goin on, and I was kinda sick of it.
I'm gonna try and bleed them one more time, then start pulling things apart.
Any thoughts on what might be the source of this problem?
Also, are you bleeder screws pointing up?
