Drag Racing Tech
rearend fitment with min tubs
Old 02-15-2010, 03:11 PM
92slowmaro's Avatar
Default rearend fitment with min tubs
i have a 1992 camaro with a strange 12 bolt that is made for the thirdgen camaro so its shorter than the 4th gen rearend.
im contemplating buying a 98-02 roller and putting my ls1/th400 12 bolt swap in it because ive always wanted a 4th gen.
if i minitub the 4th gen will my thirdgen rear fit with 28x12.50-15s on a 15x10 w/5.5 bs... or what kind of spacers will i need to use factory 4th gen rims?
i essentially want to build a track only car. just weighing my options...
thanks.
Old 02-15-2010, 03:36 PM
9sec93's Avatar
you wouldnt need to mini tub. i think those wheels will work fine without spacers. may even need a 6.5" backpace so they dont stick out. im not exactly sure how much shorter the 3rd gen rear is over the 4th gen rear. i thought it was 1" per side or a bit more.
Old 02-15-2010, 03:46 PM
SoundsZ28's Avatar
im almost positive that the thirdgen rearend is 1" shorter than a fourth gen car
Old 02-15-2010, 05:39 PM
Zmg00camaross's Avatar
The third gens are 1.5 inch shorter on both sides the a 4th gen. so to be correct would be 6.0 back spaceing, you probly could get away with 5.5 bs maybe a little hammering.
Old 02-15-2010, 07:58 PM
92slowmaro's Avatar
cool i may end up getting the 6.0 b.s.
Old 02-15-2010, 08:09 PM
9sec93's Avatar
with the 6.5" backspace it will tuck in a little better. you may need offset control arms and a little massaging of the inner wheel well depending on how wide of a tire you run but it will look good.
Old 02-15-2010, 08:18 PM
92slowmaro's Avatar
sounds good. ive got a decent drivetrain to swap over so it should be sweet once im done... thanks!
