mystery missfire in cylinder 6
OK here it goes i have a slight miss thats noticable at idle and can be seen
on a scanner so i tried swapping wires they are msd and nothin then i put in
a new plug then swapped injectors then coil packs and the problem never
moved or changed i checked compression for the hell of it and it was at 125
hooked up a vaccum gauge to the car and it was steady so im out of ideas
the only thing i can think of is that the scanner is reading the wrong cylinder
because i read on here somewhere that some scanners mix up cylinders 6
and 8 but other than that im dry
