ever used a metal lid?
Old 02-17-2010, 06:54 PM
zaaronz's Avatar
Default ever used a metal lid?
I like the look of this lid, i think it would look good on my silver ta. I have never seen one on the ls1 tho. They are pretty cheap (ebay). Has anyone here ever used one? I was wondering how it fits, and they say it fits the stock maf but they recommend a coupler for a good seal. If you have one did you use a coupler? If so what did you use? The only couplers i see anywhere are slp bellows. Arent they usually for between the maf and tb, not the lid and maf? heres a link to pix, i dont know how to get the pix on the page http://s949.photobucket.com/albums/a...t=metallid.jpg
Old 02-19-2010, 02:07 AM
FatZ28's Avatar
That thing would have to heat soak really bad. You would probably lose performance over a stock lid.
Old 02-19-2010, 08:33 AM
MonmouthCtyLS7's Avatar
Yea I would think the only problem would be heatsoak
Old 02-19-2010, 11:13 AM
Hamrdown's Avatar
That thing looks pretty bad ***. If you want to make it work and not heat soak that much then have the inside of the lid thermal coated. There are plenty of shops out there that can do this and doing so on the inside of that lid would be easy and not very expensive.
Old 02-19-2010, 03:08 PM
slayerized6's Avatar
use plastic....weight savings, no heat soak.
that metal lid is only good if you got a show car and like to have ever things polished
Old 02-19-2010, 03:35 PM
406malibu's Avatar
That would also make the inner dimensions smaller. Its a double edged sword, have heat soak and lose power, or have a smaller diameter and lose power.
Unless its JUST a show car I see no advantages to this lid.
Old 02-19-2010, 04:00 PM
MikeG's Avatar
Yep, what everybody else said. It looks badass though!
Old 02-19-2010, 06:02 PM
Blane's30thTA's Avatar
figures i just got mine in mail today, what is all this heatsoak talk? lid getting hot?
My lid doesn't sit very well on mine,
while i have your attention, what is the little sensor for that plugs in the lid??
Old 02-19-2010, 06:19 PM
Hamrdown's Avatar
Air intake temperarure sensor. I'd run it. I don't think it will be as big of a deal as others are saying. Enjoy it. It looks friggin' sweet.
Old 02-19-2010, 08:06 PM
zaaronz's Avatar
you may have been the one that outbid me then? just kidding- Im still thinking about it, not sure if this is the one i want or not. Deff dont like the heat soak, i never even thought about that. Let me know how you like it and did you use a coupler like they said(what did you use)? If i dont get this one i also like the look of the mti clear lid..
Old 02-19-2010, 09:56 PM
FatZ28's Avatar
Heat soak is basically just a piece (in this case the lid) absorbing heat and then transferring that heat to the air. Hotter air means less horsepower.
Old 02-19-2010, 11:01 PM
therealcreeper's Avatar
looks pretty tacky to me, oh well
Old 02-19-2010, 11:08 PM
95_transam_lt1's Avatar
looks real nice. honestly if you think that 1/16" piece of metal is going to get heat soaked bad and cause performance your gettin pickey or drivin a honda just sayin
Old 02-20-2010, 12:29 AM
VXTCSS's Avatar
there's a few blokes out here in Australia that use the metal airbox lids... and honestly, they absorb the heat really bad and the inside turns into an oven. You may as well stick a blowtorch on the end of your intake pipe and start the car. Not a good idea to use them unless you change it from plastic to metal for a car show.
Old 02-20-2010, 12:43 AM
GO BABY GO's Avatar
Heat soak wont be horrible. Thin metal like that with air moving across it probably wouldn't be an issue. Look at how many people are running the metal ram air induction. They lost no power when the car was moving.
Old 02-20-2010, 03:36 AM
VXTCSS's Avatar
depends on what summer is like mate... over here its bluddy hot
Old 02-20-2010, 05:23 PM
FatZ28's Avatar
Same here in Texas VXT. 100 degree day's are not that uncommon.
Old 02-20-2010, 05:30 PM
deelong4002's Avatar
I'd be suprise if it heat soaks that bad. Do the free ram air mod, and i bet it doesnt affect it much at all. The intake is so far away from the motor on these cars it cant be that bad. Unless you have a 1000 hp car, the loss if it does heat soak is going to be negligable anyway.
Old 02-20-2010, 05:33 PM
Nevermind, the ones i found are $189. You could get the FTP Clear lid for that much. If it was 50 bucks i would say go for it
Old 02-20-2010, 06:38 PM
what free ram air mod?
Quick Reply: ever used a metal lid?
