Anyone tried one of these?
http://www.jegs.com/i/Car+Chemistry/176/3FI03L/10002/-1
supposedly it quiets down your exhaust a little bit without killing any HP.
it would be nice to rid of that god awful drone on the highway, maybe i could actually talk on my phone then....or wait, maybe its better i cant drive and talk at the same time
I've always wanted to try these:
http://www.summitracing.com/parts/DTC-72-32520/
or these:
http://www.summitracing.com/parts/DTC-M80-00100/
Seems like a cool idea, and it looks like it would flow better than the collector insert.
or these:
Looks to me like all you are doing is restricting exhaust flow. You are putting something in the way of ther exhaust's path to freedom. If you care about the volume, then why bother with a V8 and a performance exhaust system? Just saying.
Exhaust sound isn't the only reason to bother with a v8. i really hope thats not the only reason you bought your car.
I bought my car with the loudmouth on it. i swapped out the slp bullet for a magnaflow one and it made a noticeable reduction in the drone, but it still bothers me. And im not gonna buy a whole new system.
Sorry if my comment came off as unpleasant...
And I am not implying that exhaust sound is "the only reason to bother with a V8". I am simply saying that a loud exhaust goes along with a performance engine. What I am saying is that if you want a nice V8 and a quiet exhaust, then you have to choose which one of those criteria is more important to you.
That being said, I understand now that you don't want to muffle your volume but rather eliminate the highway drone, which is understandable. Once again, sorry if my previous comment read the wrong way. I mean no disrespect to anyone...
Also, I can't imagine buying an LS1 F-body based on its sound only, when there are so many other reasons to love it.
Kleeborp the Moderator™
Lookie what I found:
https://ls1tech.com/forums/generatio...-question.html
Excerpt from that thread:
If you think putting that ginormous hunk of **** in your exhaust won't reduce power, you are on crack.
Do not use the Car Chemistry inserts that Summit sells unless you want to lose alot of power! I installed a 3" 2 disk version into my 3" I pipe right after my cutout to cut down on rasp with my old exhaust setup and it lost me 33rwhp @ 34rwtq over an open cutout. Runs were done back to back. This is on stock heads w my current TR224. I know the graph says LS6 cam but that's because Mikey had not updated my data file since the I was running the LS6 cam.
