Anyone on have a part number....
Old 02-19-2010, 10:42 PM
rtr2001ss's Avatar
Default Anyone on have a part number....
For a 9" Moser axle bearing and axle seal? My right seal is leaking and figured I should get it replaced. Car is 4ch if this makes any difference to the axles.
Old 02-19-2010, 11:02 PM
SS SLP2's Avatar
This is info I have I have not had a need to check it out
"FWIW, my axles/bearings were supplied by Moser, but the housing is a Quick Performance. Uses the same interal stuff as Moser, even the axles are the identical lengths etc..
Napa Part Numbers:
Bearing = 88128-R
Inside Seal = 15142
I hope it is correct, Johnny
ps: from one of our great vendors (thanks Bob)
you can use regular axle seals. What I would do is to go to your local parts store, and tell them you need the seals for a 1975 Ford pick up with a nine inch. Same goes for bearings if you ever need them.
__________________
Old 02-19-2010, 11:11 PM
rtr2001ss's Avatar
Napa Part Numbers:
Bearing = 88128-R
Inside Seal = 15142
ps: I have been informed that the seal and bearing are the same as thoes used in the 1957 ford pu with 9"
This here alone could make the lookup easier. Maybe a sponsor will pop in with some knowledge and be sure I get the correct stuff.
Old 02-20-2010, 06:14 AM
EPP
EPP's Avatar
Thumbs up
Napa Part Numbers:
Bearing = 88128-R
Inside Seal = 15142
__________________
You're welcome. Bob
Old 02-20-2010, 10:30 AM
rtr2001ss's Avatar
Napa Part Numbers:
Bearing = 88128-R
Inside Seal = 15142
So these WILL work for the Moser axles? If so, that's all I needed.
