Drag Racing Tech
steering wheel
Old 02-20-2010, 12:20 PM
383racecar's Avatar
Default steering wheel
looking at putting a different steering wheel in my 1995 camaro because i removed the air bags, was wondering what steering wheels you guys are using,what diameter,i have no power steering,tubular everything up front,3450lbs race weight with driver, im looking at http://www.jegs.com/i/Grant/470/1075/10002/-1 is the 13in diameter to small with no power steering? and what install kits work with the stock column. thanks
Old 02-20-2010, 02:26 PM
LS1TECH Sponsor
Steve Burger's Avatar
we have a removable kit that is SFI certified.
Old 02-20-2010, 05:15 PM
sweetbmxrider's Avatar
you can do a fixed hub or removable hub. grant sells them as well.
Old 02-21-2010, 11:20 AM
383racecar's Avatar
i cant find a fixed hub for a 1995 camaro does anyone have a part # for one that will work??
Old 02-21-2010, 11:59 AM
LS1SpeedAddict's Avatar
will your kit work with any grant wheel?
Old 02-21-2010, 01:09 PM
http://www.summitracing.com/parts/GRT-3196/?rtype=10
that should work. sometimes people have issues with the wheel rubbing the column so they stick washers in there to space it out enough to clear.
https://ls1tech.com/forums/drag-raci...eel-today.html
Old 02-21-2010, 02:24 PM
383racecar's Avatar
thanks
