New Alternator Help!
Hey LS1ers, i need to up the ante when it comes to my alternator. Any advice? I dont have a monster audio system but there is a sub and amp. I also just got a set of ASP pulleys for the under drive as well as the alternator. I know this will draw even more from the factory alternator. Any thoughts and price?
if you're going to run an amp and sub, dont run both the crank and alt. under drive pulley... you'll draw too much power. Instead stock alternator and an overdrive pulley should get you enough power
