Rear drag springs
Old 02-20-2010, 05:29 PM
Ram4whldr's Avatar
Default Rear drag springs
I just ordered my (almost) complete suspension. I am having difficulty determining which rear spring I should go with for street/strip setup. Most driving will be around town on the weekends or at night. Car is not a daily driver. It will however see a lot of strip time. Some people say stay with the stock rear springs and some say go with stock V6 springs. I have not been able to find a set of rear aftermarket drag springs to replace the stock rear springs. Can somebody point me in the right direction.
Old 02-20-2010, 08:50 PM
kierstyn's Avatar
Stay with the stock springs and save the money for other suspension stuff like anti-sway bar or sumthin else.
Old 02-21-2010, 10:08 AM
StealthFormula's Avatar
Like said just stick with the stock rear springs. Maybe cut a coil or so out if you want the lower the right height.
Old 02-22-2010, 06:27 AM
Ram4whldr's Avatar
Anyone else? I already ordered a rear drag bar, k member, a arms, torque arm & relacation bracket, lower control arms and relocation brackets, panhard bar, QA1's, front springs. I just need to know what I should do about the rear springs.
Old 02-22-2010, 08:05 PM
kierstyn's Avatar
Most people stick with a stock spring and do a adjustable shock but you could also do a coilover setup in the rear if you wanted ton go that way.
Old 02-23-2010, 12:05 AM
blown03mustang's Avatar
i run a hotchkis spring in the rear with a strange DA. strange coilovers in the front. rides better than stock i think and still hooks hard as a ****. i called a few of our sponsors and they all said that a lowering spring in the rear wont hurt 60' times as long as the suspension is setup correctly. just my .02
Quick Reply: Rear drag springs
