AEM W/B A/F , come in please
next week i'll order the AEM Wideband Air / Fuel Gauge the gauge comes with sensor , and there are two 02 sensors plugged in the right/left side on my headers , so where i should plug the AEM sensor ?
thanks in advance
thanks in advance
You will need to get an 02 sensor bung welded in somewhere, I'd recommend the drivers side bank because of the #7 cylinder tending to be the leanest. The only way you would be able to remove one of your current 02's and put this in its place is if you got a tune that would not require your narrow band 02 sensors. The AEM W/B kit may or may not come with an 02 bung, if it doesnt you can get them from most sponsors or other performance parts suppliers. :cough: Bring it to an exhaust place and they can weld it in for you for pretty cheap.
