Ground wire to aluminum block
If the LS-1 is an aluminum block why is there a groulding cable runing to the block above the starter .
I had been told aluminum does not make a good ground . Is this false ?
Ungrounded Moderator
Aluminum is actually more conductive than copper and was used for many years in household wiring. Unfortunately, aluminum has other problems that ended up making it unsuitable for household wiring. For example, it expands and contracts at much different rates than other conductors causing connections to come loose. It also tends to form surface oxidation over time that reduces current flow (this can be overcome by using plenty of dielectric grease).
Those problems don't really apply to a ground cable on an aluminum block. It's not like wires twisted together with a wire cap so the connection doesn't come loose and liberal use of dielectric grease keeps the oxidation problem from occurring.
