New Products Showcase - Kaltech Ported Cylinder Head Series
Kaltech Tuning
02-22-2010, 09:19 PM
I wanted to make everyone aware of a new line of ported cylinder heads we'll be releasing shortly. Many of you have seen how some of our higher end cylinder heads have performed both on the dyno and at the track but I'm also seeing an increased demand for more budget oriented heads and those are the newest series of heads we're working on. We'll be releasing 2 new stages of ported 243/799 heads that will be available under $2000 with springs.
Some of the highlights will include new GM castings, hand porting, milling, and dual springs as the base setup with available upgrades.
The Stage 1 heads will gain 25-30 hp over stock and be priced under $1700 with springs.
Stage 2 will be good for 35-40 hp over stock with pricing just under $2000.
As always you can opt for our higher end ported ends which will pick you up 50 or more hp. These setups can be based around more typical rpm ranges (under 7000) or more radical high rpm setups using titanium valves.
