Where is crank-trigger wiring at? Trying to install Timing Tuner!
I did a search and found that it is behind/on top of alternator. The posts said to remove alternator (I did)...and I found a wiring harness behind it. The problem is that the wiring harness that I found behind the alternator is a four-prong plug (square style) and the wiring I have from the Timing Tuner is a three-across style plug. Obviously won't fit. I can assume two things:
1.) Ramchargers gave me a wrong unit, not made for 2000 Camaro
-or-
2.) I am looking at the wrong wiring harness.
Does anyone know for sure where the crank trigger harness is on a 2000 LS1 Camaro Z-28? I cannot find any other harness in that area, and no other harness around the engine compartment looks like the right one.
Thanks,
SDB
-or-
Thanks,
SDB
The 4 pin harness you found should be for the oxygen sensor. The crank sensor is near the starter, otherside of the engine.
Gary
Gary
-or-
Thanks,
SDB
-or-
Thanks,
SDB
