Plumbing an accusump
Old 02-26-2010, 01:02 PM
boxmod's Avatar
Default Plumbing an accusump
I have a 99 Ls1 that will be using a GTO oil pan setup. I want to run a 3 quart accusump with a manual valve. I can't get solid information anywhere.
Is there a port I can plumb the accusump directly into an oil galley? Or a extrernal line to run a T-fitting and check valve?
If so what would the fitting size be?
I considered the sandwich adaptor but I dont want the filter sitting too low catching debris, and I also don't think its 100% needed to relocate the filter.
Also, what pressure should I set the sump to? I've read a few different things and it all seems to be conflicting information so far.
Thanks in advance.
Old 02-26-2010, 02:23 PM
gtpvette's Avatar
Go over to te Corvette forums,,, Autocrossing & Roadracing section LOTS of info there.
http://forums.corvetteforum.com/auto...roadracing-23/
Old 02-26-2010, 08:51 PM
Bo185's Avatar
Try one of these
http://www.pirate4x4.com/forum/showthread.php?t=816350
Old 02-26-2010, 10:31 PM
boxmod's Avatar
that looks AMAZING, im calling them asap. thanks a bunch!!
Quick Reply: Plumbing an accusump
