OBD1 / LT1 Tuners needed in orlando!!! Cash in HAND!!
hey guys, i am in need of a desperate look at my tune! i have a 94z with some shifting issuses. now here is the problem. the car drives and idles great! its as soon as i go into WOT that the car does not shift. even if its in any gear or any mph, even if i manually do it, it still does not want to shift . i have to let off the gas and it will finally shift 3-5 secs later. i cant figure out why i keep hitting the rev limiter. if i mash the gas at 45mph, the car runs very strong intill it trys to shift. i have replaced the tps,vss, and added extra oil.(some ppl told me to check those things). i just want to make sure my shift points are on point, and check some other things. i dont really need a tune, just need to look at a few tables. I HAVE CASH IN HAND!! im located by the airport, and will meet up anywhere in orlando.
here is a list of the mods
Engine:
GMPP 218/228 .525"/.525" Cam
GMPP 1.6 Roller Rockers
GMPP LT4 Valve Springs
GMPP Lifter Set (Replaced at 78,7XX miles)
Hypertech 160* Thermostat
Exhaust:
Pacesetter Ceramic Coated Longtube Headers
3" Off Road Y-Pipe & Custom 3" Catback
3" QTP Cutout
Flowmaster 40 Series Muffler with Dumps
Drivetrain:
Pro-built Automatics Rebuilt 4L60E with cryoed reverse/input drum and HD sleeve
Transgo Vacuum Modulator & Transgo Stage II Shift Kit
PI Vigilante 3000 Stall
LS1 Aluminum Driveshaft with Lakewood Performance U-Joints
B & M Tranny Cooler
T/A Performance Rear End Girdle
Suspension:
Spohn Tubular Lower Control Arms
Spohn Lower Control Arm Relocation Brackets
Spohn Strut Tower Brace
Spohn Subframe Connectors
Ignition:
NGK TR5 Spark Plugs
MSD 8.5" Super Conductor Plug Wires
MSD Ignition Coil
LT4 Knock Module
any info would help alot.
thanks
Adam
Engine:
Exhaust:
3" QTP Cutout
Drivetrain:
B & M Tranny Cooler
Suspension:
Ignition:
NGK TR5 Spark Plugs
MSD Ignition Coil
LT4 Knock Module
thanks
Adam
