where install oil pressure gauge
Old 02-27-2010, 02:36 PM
linebacker50's Avatar
Default where install oil pressure gauge
is there another place that i can hook up a aftermarket oil pressure gauge besides at the oil filter housing?
Old 02-27-2010, 09:14 PM
blue00ZZleeper's Avatar
Nope. Thats the best place to do it. Its held on by 2 10mm bolts. Theres threads in the FI section seeing as how the APS turbo guys do it. Also lists all the needed tools and how to do it
Old 02-28-2010, 06:01 PM
theres got to be another way of manually testing you oil pressure. long story short my OPSU might be bad or my oil pump and i need to know what my oil pressure really is. so it doesn't have to be something permanent just a way to get a manual reading.
Old 03-01-2010, 02:37 PM
bumpppp
Old 03-01-2010, 03:12 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
really the only other place is to put it where the oil pressure sending unit is
Old 03-01-2010, 07:55 PM
meaning i have to take off the intake just to reach back there to change out the OPSU?
Old 03-01-2010, 08:19 PM
Z28/2002's Avatar
Unless you can get back there without removing it, but if you take it off you might as well just replace the unit
