installed my 12 bolt
Old 02-27-2010, 08:57 PM
BlueRamAir's Avatar
Default installed my 12 bolt
I put my moser 12 bolt in last night. It was kind of a PITA. My question is I couldn't hook up my sway bar since the moser tubes are obviously larger than on the 10 bolt. Where can I get an install kit that will hook up my sway bar correctly?
Old 02-27-2010, 09:42 PM
99FBODY's Avatar
I know Speed inc has them, I have to get the same install kit for my 9in.
Old 02-28-2010, 07:51 AM
EPP
EPP's Avatar
Here is a quick way to do it. You can use 3 inch exhaust clamps, you only use the U part of them. Reuse the bottom part of your oem sway bar brackets, you have to oblong the holes out a little towards the outside. Bob
Old 02-28-2010, 10:22 AM
Ironxcross's Avatar
What he said, works perfect.
Old 02-28-2010, 10:06 PM
BlueRamAir's Avatar
Good info. Thanks!
