shocks and springs help needed!!!
I have a 2002 ws6 trans am..i am installing eibach lowering springs and qa1 adjustable shocks I also have bmr shock collar. The problem I'm having is the front end is too low and I'm @ 3/4 up the shock on the spanner nuts... is anyone tried this combonation any suggestions? What am I missing?
Which Eibach lowering springs?
LT1 pro-kit, LS1 pro-kit, Sportline?
How much higher do you want it, and much adjustment range is left on the shock spring seat?
FYI, if you want it 1" higher, then just adjust the spring seat up about 1/2".
Just adjust the spring seat 1/2 the distance that you want to change the ride height.
