Broken Rear Sway Bar
So I lifted my car up yesterday to swap out the slave and noticed my HOtchkis rear sway bar was broken in half about an inch inside the sway bar linkage. Jagged break, Any thoughts as to how this could have happened? Gotta contact them tomorrow and see about the warrenty, its 2 and a half years old.
Had the same thing happen, very likely the bushing wasn't greased, and it seized up on the sway bar, so next bump you hit, all that weight snapped the bar. Make sure to regrease those bushing every once and a while, it has a fitting specifically for that.
I would think a seized endlink would break before the swaybar would. I've seen that happen on other cars.
LS1TECH Sponsor
Yeah... not for nothing, but a swaybar should not be breaking. If it did it had a flaw... I'm pretty picky about such things, and while one can't count out rust as a factor, I think more likely the bar material was just poor. The fact this has happened to others with the same bars, makes me think it was a batch of tubing that was bad.
I've never had to deal with that issue, and don't plan too.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
