spec clutches
spec clutches
whats the difference between the spec stage 3 clutch and the spec stage 3+? also where is the best least expencive place to buy the spec clutches. thanks!
Our Stage 3 kit uses a pucked carbon-semi-metallic disc design and as such will have a quicker engagement and release. It will also have a lower MOI as a result of the lower rotating mass when compared to the Stage 3+ which uses a heavier full-face carbon-semi-metallic disc design. The 3+ has a higher torque capacity and will be more drivable. What are you planning to make in terms of torque and what type of usage will the car see? Let me know and I will be happy to assist you in making the best choice for your needs. Thanks,
Spec stage 3+ clutch is killer. Im planning on doing this this spring. I know, if you go to WS6store.com, they have them there for around $535. probably the cheapest place I know to get this clutch.
yeah, just checked, WS6 store would be cheapest. Ultrarev.com has them on sale right now. They are giving a 7% discount on spec clutches. so it would be around $505.
