Hooked a battery charger up,Now my WS6 wont run???????
Old 03-01-2010, 05:36 PM
pats'00WS6's Avatar
Exclamation Hooked a battery charger up,Now my WS6 wont run???????
OK first off i went out to work on the TA and the battery was dead so i hooked the charger up to the battery and it started and i pulled it out of the garage. About 8-10 hours later i went to hook the charger up again and it would not start but it cranked and cranked so im wondering if i may have fried something in the computer system?????????? Any help will be greatly appreciated!!!
Thanks
Old 03-02-2010, 08:35 AM
Old Geezer's Avatar
Checked the fuses??
Old 03-02-2010, 04:37 PM
pats'00WS6's Avatar
yes i checked the fuses and that wasnt it. I also have heard it could be the crank sensor but im not sure?
Old 03-04-2010, 12:07 AM
1_fast_gto's Avatar
wow. any security lights on? flashing? any codes set in ecm? do you have fuel pressure? just some quick checks to do before trying to reach the crank sensor
Old 03-04-2010, 06:43 AM
01Z28M6's Avatar
Right, checking for DTCs should be your first course of action after the visual stuff.
