Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
diff bushing tool?
Old 03-01-2010, 10:45 PM
TomJoeC88's Avatar
Default diff bushing tool?
i know such a thing exists for rear diff bushing removal, but cannot find where to buy one. anyone know?
Old 03-02-2010, 06:04 PM
CTS-V Shifter Sales
07CTS-V's Avatar
They are over $300 to buy one new from GM. I loan one out. Search for my other forum name PISNUOFF.
Old 03-02-2010, 09:18 PM
NeverSatisfied02's Avatar
Dude, you are PISNUOFF?
You make the short throws for these cars right?
Old 03-04-2010, 07:28 PM
CTS-V Shifter Sales
07CTS-V's Avatar
That's me. A little more low profile over here.
Old 04-14-2010, 05:45 AM
Grifter's Avatar
The problem with the GM tool is it won't remove it if the bushing is broken, which they usually are.
Old 04-14-2010, 03:57 PM
MIGHTYMOUSE's Avatar
can somebody give me the dimensions of the factory bushing.. including the shell, and/or the hole size of where it goes pretty please.
i have a line on some very cheap bushings that might be a perfect fit.
ID where bolt goes=
OD of bushing shell w/ bushing inside=
lenght of center anti-crush sleeve inside bushing=
Old 04-14-2010, 07:46 PM
Big Bu Bu's Avatar
Where is that thing anyway? I'm on the list somewhere. Crankedupforit on the other forum.
Old 04-16-2010, 07:18 AM
CTS-V Shifter Sales
07CTS-V's Avatar
Mine will take out a broken bushing. The spacer that is pushed/pulled through the bore is only slightly smaller than the bore itself.
ID where bolt goes=
I don't have those dimensions on me, but I have a stock bushing you can have. Just pay shipping. PM me.
I have two of them loaned out. They've both been out for quite a while. Hopefully one will make it's way back soon.
Old 04-16-2010, 09:55 AM
is it new? if not i'd just assume you make the measurements for me
Old 04-16-2010, 11:38 AM
SoJersey05V's Avatar
Pisnuoff can u let us know wen it gets back around? I will need this tool sometime soon too... not on cf tho (f_them)
Old 04-16-2010, 12:48 PM
CTS-V Shifter Sales
07CTS-V's Avatar
I have a new one sitting around collecting dust.
You're 3rd in line.
Old 04-16-2010, 06:46 PM
You're 3rd in line.
Thank you sir!
Old 04-18-2010, 08:33 AM
Grifter's Avatar
Would you be able to post a picture of the tool? I only ask because I'm a Cadillac tech and just did a V bushing the other day. The tool I used will not work if the rubber bushing is seperated from the metal sleeve since it's designed to push on the metal insert that's part of the bushing.
Old 04-18-2010, 10:28 AM
CTS-V Shifter Sales
07CTS-V's Avatar
I've done a couple re-designs, but here is what it used to look like. The round insert is now steel and thinner, the cup is now a little shorter and the threaded portion of the cup is thicker. You can either push or pull the round insert through the bore. It actually works better without the rubber portion of the bushing connected.
Old 04-19-2010, 04:47 PM
can somebody measure one of these bushings they have sitting around please.
Quick Reply: diff bushing tool?
