What calipers/rotor combo will clear prostars?
Old 03-02-2010, 03:37 AM
therealthatguy's Avatar
Default What calipers/rotor combo will clear prostars?
I started grinding on the front calipers the other day, and i still have ALOT to go, so i was wondering which caliper/rotor kit/combo will clear prostars without issues. Figured it might be better in the long run, if not i will just get some spacers and continue to grind and grind.
thanks for the input!!
Old 03-03-2010, 12:18 PM
Bad Blu Formula's Avatar
Are you talking fronts of rears? For the fronts, I didn't have to grind at all. I just used a 3/16" spacer and called it a day. The rears are a little different considering you have to worry about the studs. Longer ARP studs with a spacer can help avoid some of the grinding.
Old 03-03-2010, 12:23 PM
Zmg00camaross's Avatar
strange drag brakes will help you out. Check some sponsors around here on the site.
Old 03-03-2010, 12:57 PM
IWGF's Avatar
I just used a 3/16th spacer and had to grind a teeny tiny bit on the front.
On the rears I have long studs, a spacer, and a ton of grinding...
Quick Reply: What calipers/rotor combo will clear prostars?
