Oxygen sensor plug
Oxygen sensor plug
I have just started cutting into my harness and ran into a snag. This is for a 2002 lq4. The front o2 sensor has no pink wire going to it. Here is what the connector looks like.
These are the wire colors going to the connector.
Purple/white
lt green/white
lt green
tan
The rear 02 sensor has a pink wire in it and it uses a square plug. Does this just mean that only the rear 02's are heated.
Purple/white
lt green/white
lt green
tan
LS1Tech Premium Sponsor
No, the front have a heater as well, they just use different colors than your rears do.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
