00 air removal quick advice....
im takin my air off my car and on the back of the motor there is a round thing with a small hose on top of it...does this come off and if so how...its on a type of bracket...does the bracket come off...
and yes i know there is stickys but im in the process and need a quick answer...thanks in advance guys
Can I ask what you ended up doing? I am doing a header install and just pulled that piece off and see a tiny hose back there. From what I have seen around here, you just plug it up. I was planning on electrical tape, but curious if there is a better method.
Steve, you just pull that whole round thing out with the hose and cap where it connects. You use a cap instead of a plug because it's a vacuum connection.
Thank you very much. I am finishing up tomorrow morning. Making an auto store run now to pick up the cap, restock on pen lube, and figured I would do an oil change too, it's a little early, but oh well. I have the drivers side Header up and in there. The passenger's is off, just need to slide up the new one.
