Drag Racing Tech
ID these boxes under dash
Old 03-08-2010, 02:46 PM
InsaneAuto86's Avatar
Default ID these boxes under dash
Please help me ID these. Car is a 1995 z28:
Under steering column:
Attached to brake pedal:
Old 03-08-2010, 09:51 PM
csjta2's Avatar
I'm not positive but I will try to help
The first pic, the 2 black boxes, one is the Express Down Window Module, it makes your drivers window go down when you hit the switch. The second is the Chime Module.
2nd pic looks like the Keyless Entry Receiver, is that mounted on the right side, behind the kick panel?
3rd pic, these go to your turn signal switch, everything in the sterring column goes thru these 2 connectors
Last pic, brake light switch, the top switch i think is the Cruise Control Disconnect Switch
Old 03-08-2010, 10:07 PM
meangreenchevy's Avatar
also i think that teal connector has the vats system in it
Old 03-09-2010, 06:37 AM
What is a chime module?
Old 03-09-2010, 07:30 AM
csjta2's Avatar
The chime module is what makes noise when the key is in the ignition. I might be wrong about one of the black boxes being the chime module, it might be the high blower relay, not sure but I will try to find out.
Old 03-09-2010, 09:06 AM
I already removed one black box that said "TRW" on it which I assume was for keyless entry. I think the box with the teal connector is the VATS stuff.
I need to know if both those connectors under the steering shaft are for. Is one for airbags? Mine are gone so if so I need it gone too.
Old 03-09-2010, 09:58 AM
sweetbmxrider's Avatar
airbag connector is yellow and marked. 1st pic 4 wire connector is going to express down module but the other thing may be the RAP (retained accessory power) module. been awhile since i've seen one. it sits on the firewall towards the driver side over the tranny hump. if you can get part numbers i can probably identify all of them. i agree with the other things that csjta2 said
Old 03-09-2010, 01:18 PM
LadyDriven's Avatar
Subscribing! I was just wondering about these on my car as well!
Old 03-09-2010, 06:31 PM
lt1badbird's Avatar
yep one is the express window down module. the other is the retained accesory power module.
just came in from doing this today:
Old 03-09-2010, 07:38 PM
good god! nice nest.
sweet i was right
Old 03-11-2010, 10:17 AM
You guys were correct. Just removed the RAP and express down modules and re-wired the power windows.
Fuse 16 - crank - 3a I have yellow ign wire going to the fuse box and a ppl wire exiting - where does the ppl wire go? Looks like i've had it disconnect for a while now.
Old 03-11-2010, 10:55 AM
If anyone needs the keyless entry box, RAP box, or express down box, let me know.
Old 03-11-2010, 01:20 PM
fuse16.jpg?t=1268335164
any other crap pm me or post up!
Old 04-24-2010, 01:49 AM
MrElectric03's Avatar
Interesting, I just started tearing mine apart tonight, how different are the LT1 cars from teh LS1 cars? I have a 98 Formula that I would really like to pull these boxes and the wiring.
Old 04-24-2010, 08:12 AM
Do it. I got rid of pretty much everything in the car.
Old 04-24-2010, 10:42 AM
And no starting issues huh? SO far I pulled out the entire harness down the right side(rear speakers, factory amp, power ant.) and the entire console harness(cig light, acsy power, brake switch, airbag sens, ash light). Now I want to start pulling the dash wires out but that stuff makes me nervous when I dont know exactly what they are.
Old 04-24-2010, 07:55 PM
None at all. Traced every wire to its source before chopping it out.
Old 04-25-2010, 01:43 PM
post up if you have questions or need help identifying wires MrElectric
Quick Reply: ID these boxes under dash
