Do you have to use mcleod's flywheel with a street twin?
If it is for a LT-1 yes you do because the floater plate pattern is drilled in the flywheel. Also the flywheel is thinner than a regular single disc flywheel to keep the overall stack height within the factory 4.950" bellhousing.
