Turn signal blinker or bulbs?
My blinkers started to act kinda weird. Yesterday they were blinking really fast. This morning they did the same but this time the blinking is more like a flicker and they dont stay on. Any ideas before I start taking the dash apart?
when ive seen that it normally means the bulb is dying....not burned out.......just needs a new replacement and cannot supprt the power of the battery and what not....just what i heard of....when a turn signal flashes too quickly
Ungrounded Moderator
If both sides do the same thing, it's probably the flasher. If only one side has the problem, it is either a bulb or a bad socket on the side that doesn't work. Turn on the hazard flashers (they use a different flasher) and walk around the car looking for the light that doesn't work.
