Converting...and mileage
Old 03-14-2010, 02:48 PM
Chadmn's Avatar
Default Converting...and mileage
Someone mentioned the other day that he did his 67-69 Camaro and was getting like 16mpgs and it made me think. Back in the TPI days, there were a few street rod guys talking about how they were getting 28 mpg with 331 and 308s with like a 25-27 inch tall tire in 37 Fords, 63 Nova wagons, etc.
Now if one was to do it with an LS1 setup...what would be your choices. 5.7, 5.3, 6 speed, auto?? What would you do for a tune? Cast manifolds or headers? But the main question is why??? How does one really geek out on this to make the most MPG?
Chad
p.s. I know little about doing a tune or flash on a LS1
Old 03-14-2010, 05:59 PM
Jimbo1367's Avatar
If you wanted pure milage def. the 6 sp. I doubt there is ALOT of difference in fuel between the 5.3 vs. 5.7 given same driving.
Old 03-15-2010, 12:19 AM
Bo185's Avatar
Chad
My choice for max MPG would be 4.8L 6l80 and 3.08's! Hell the 5.3l/6l80/3.08 in the Silverado XFE Fuel mileage addition is getting 22 hwy so a car should get alot better than that.
Lower the car and reduce weight. Most savings will be by reducing weight and keeping your foot out of it.
Old 03-15-2010, 10:24 AM
Chadmn's Avatar
Reason why I ask is that I hear few that actually get high MPG other than the 2000 Vette guys.
The other day coming home 2 hours from a customer in my work van with a dmax 480 combo I got 27MPG loaded down at 9700#. If I can get this with a fat van..what can I do on something 1/3 of its size.
Old 03-15-2010, 01:59 PM
Bo185's Avatar
Diesel's alittle different. The fuel itself is more powerful per gallon vs gas. So it takes less fuel per mile for the same with gas motor.
I think most that swap LSx motors are looking for power and not really Max MPG and power. Plus its hard to keep your foot out of it. I couple of hard WOT pulls and you ruin your MPG on a given tank.
Old 03-15-2010, 06:37 PM
Jimbo1367's Avatar
Bo185,
I would think the 6M would give better milage than the 6L80E. Yeah... it has the DEEEEEEEP 1st, but what is the 6th gear? Then you have to concider extra cost. paddle shift and custom mounting etc... I could of got a 6L90E w/30K for $800.00 I think it was. (I bought its LY6) so you can get the trans cheap, just more of a hassle.
Old 03-15-2010, 06:49 PM
Bo185's Avatar
Bo185,
You don't need the paddle shifters or any other TUTD sifter unless you want the manual mode. It'll work just fine with out it PNRD. Just hook the shift up to any standard 700r or 4l60 shift gate shifter.
The 6l80/90 sixth OD is .66 so better than the 4l60/65/70. And with the nice first gear you can use a taller 3.08 final drive which makes up for the better T56 6 gear.
Old 03-15-2010, 11:49 PM
sawzall wielding director
G-Body's Avatar
Maybe. I might have my foot in it a few times a day . Plus I just found out today that my WOT AFR is 10:1 . Makes a lot more sense why it seemed slow at the strip.
Old 03-16-2010, 01:18 AM
Bo185's Avatar
That's why my DD is a TDI I keep my foot in it all day and still get 45mpg!
Even in a car I would think an LSx would knock down a decent 20mpg avg with numerous healthy runs at wot.
I say everyone post your swap and best MPG tank ever or even avg tank MPG with regular driving.
Quick Reply: Converting...and mileage
