Oil Pressure Sensor Volt vs Oil Pressure Formula
Trying to use the stock LSX oil pressure sendor to drive a LCD oil pressure gauge. Could someone confirm that the formula below is what is used to log the oil pressure using the LSX sensor. (I believe the same sensor is used in both ls1 and LS truck engines)
Formula:
PS1=32*V-16 (where V ranges between 0-5V)
thanks
Formula:
thanks
Formula:
thanks
Formula:
thanks
