CF strut tower brace, does it fit the 06-07 V?
It appears the 04/05 strut tower brace is mounted lower and with 2 bolts per side, whereas the 06/07 brace is taller, more substantial, welded, and uses 3 bolts per side to mount it. I was curious to know whether the GM carbon fiber strut tower brace would fit the 06/07 V since the CF brace has 2 mounting bolts per side. Seems if it would fit, it would permit more flex since it's mounted with fewer fasteners on each side.
Thanks.
Thanks.
