Stock height: LCAs pointing up going towards axle?
I have a set that I pulled from my previous 10 bolt that were welded on. They're a little bent up. I think I can bend them close though. Should work, right?
Hello
If the vehicle is lowered or even has the heater hose mod done to it. It will angle the LCA at the incorrect angle. Like mentioned above to allow you adjust the LCA to the correct position a set of Relocation Brackets will be the solution. Below is a link to show you what all UMI Performance has to offer.
http://www.umiperformance.com/catalo...39o5hov32gp3s2
If you have any other questions feel free to ask.
Thanks
Brad
Thanks
Brad
