5.3 vs. 6.0 is it worth the bills
ok i have a 97 camaro rs v6 im doing a ls swap in its gonna be carbed with a light cam and maybe heads later on but now i gotta git my motor is the 6.0 lq9 worth the $1200 or should i just go with a 5.3 $500??
Also the LQ9 is higher compression as well.
The 5.3L is cheap and a 6.0L will bolt in its place. So you could cheap out, then buy a 6.0L long or shortblock later built to your specs to swap in its place.
Either is better than the V6!
I went with the 5.3 due to funds and getting all the ls setup stuff. my intention is to move to a 6.0 down the road if the 5.3 doesn't cut the mustard. I am putting in a 70 chevelle, stock 5.3, thumpr cam and 243 heads for the time being.
If your doing heads then yes. The 4'' bore give more options for L92 heads etc...
ok thanks every one i have a couple more questions im going withe the 6.0 so my first ? is is there a way to run the efi plug and play other than the stock setup or megasquirt and my other ? is what k member should i go with?.
thanks for all the help and sorry about all the questions lol
Get a LS1 K-member and Mounts, it's cake when you use them..trust me. I wish I went that way the first time..it would've been less of a headache.
As far as wiring goes..I made my Harness plug-n-play with my setup.
Here is my swap thread, there is all kinds of info in it.
https://ls1tech.com/forums/conversio...to-95-z28.html
I know you say you are going Carb'd, but EFI is pretty simple to do with these cars.
I got the complete bottom-end for $500 on an Engine Stand delivered to the house..there are deals out there..
