2002 C5 Z06 Build - Cam & SC
1 Post
Just completed a build on an '02 C5 Z06 that started out with aftermarket headers only. The guy wanted this to still be a pretty streetable car, and so far the only issue he has is putting the power to the ground! (traction)
Details:
Vortech Supercharger w/ 3.4 pulley, V3
383 Forged LS6, 4.0 Compstar crank, 9:1
Comp Cam .590, 232/240, 116 LSA
100mm MAF
80lb injectors
Methanol Kit
Dual fuel pumps
ATI Harmonic Balancer
*Stock heads/unported
Final Results: 665 hp and 700 torque! 15 psi of boost. In the future he may upgrade the heads and maybe a larger head unit. Also, he runs the C5 on 93 pump gas and only uses the Methanol as a back-up fuel.
Details:
100mm MAF
80lb injectors
Methanol Kit
Dual fuel pumps
