Intake Manifold bolts
Old 03-20-2010, 03:25 PM
Ryneman's Avatar
Default Intake Manifold bolts
I can reuse my stock intake mainfold bolts?
If not, where can I buy some? I have been looking everywhere
Old 03-20-2010, 03:47 PM
Magic Man's Avatar
Intake bolts can be reused.
Old 03-20-2010, 05:07 PM
Ryneman's Avatar
Thanks, I cant find any anyways. lol
Old 03-20-2010, 10:11 PM
That's MISTER MODERATOR
Paul Bell's Avatar
If you wanna get fancy, ARP has LS intake manifold bolt kits in stainless steel, hex or 12 point. I'd re-use the stockers.
Old 03-21-2010, 05:19 AM
Ryneman's Avatar
I just found the ARP stainless bolts. I am not trying to go fancy right now, if it works, it works.
Don't fix it if it ain't broke
Old 03-21-2010, 06:15 AM
Predator's Avatar
I got the ARPs but the stock ones do the same job.
Old 03-21-2010, 06:22 AM
Ryneman's Avatar
I will change over to ARP bolts on the top when I get the engine running prefect. Like the intake, coil packs, coil brackets, TB. etc
I will be using ARP bolts everywhere but the heads. lol I didn't see spending that much money right now for some bolts. Plus I plan on getting different heads when I do my other LSX build.
Do the ARP bolts look nice good on the LS6 intake? Predator, did you keep your intake stock color or did you paint it?
Old 03-21-2010, 07:18 AM
Predator's Avatar
Ryneman, my intake is just stock black color. The ARP intake bolts aren't even really noticable when everything is put back together. They are nice bolts though.
I used GM bolts for my heads and I think they're great. They even come with lock-tight applied to the threads.
Old 03-21-2010, 02:29 PM
Ryneman's Avatar
Thanks again Predator. I will just reuse the stockers...for now
(Off-topic)I got the FELPRO bolts for my heads. Are these ok for a close to stock rebuild or should I get GM bolts?
Old 03-21-2010, 03:45 PM
Predator's Avatar
I don't know anything about FELPRO bolts, I just know that GM bolts are fine. Maybe someone else can chime in.
Quick Reply: Intake Manifold bolts
