Aftermarket coolant/oil gauge
Old 03-23-2010, 12:43 PM
Ryneman's Avatar
Default Aftermarket coolant/oil gauge
Has anyone used these adapters I found on Ebay to put an aftermarket coolant temp gauge and oil pressure gauge in their car?
coolant adapter Link:
http://cgi.ebay.com/ebaymotors/LS1-L...Q5fAccessories
Oil adapter Link:
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Thanks in advance
Old 03-23-2010, 12:58 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I'm running both of them on my car but mine are from Autometer
Old 03-23-2010, 01:11 PM
Ryneman's Avatar
On the items description for the coolant temp adapter, it says you can install it on the other head(passenger side) so you can keep the stock sensor in place. Is that how have yours set up?
Old 03-23-2010, 01:27 PM
Z28/2002's Avatar
I put mine in the passenger head that was it was out of the way and put the plug in the driver's side. I don't know how much of a PITA it will be putting it on the left side, I removed the HVAC from my car so it was easy for me
If you run a aftermarket gauge then yes you can keep the stock sensor on the driver's side.
Old 03-23-2010, 01:42 PM
Ryneman's Avatar
Awesome, I will do that. I plan on doing aftermarket gauges for the coolant, oil pressure and fuel pressure.
I am also removing all my HVAC/AC system but I am keeping the heater core.
You answered all my questions Z28/2002. Thanks a lot, you are the man.
Quick Reply: Aftermarket coolant/oil gauge
